SketchUp Guru
I'm thinking about adding a Cintiq 21UX to my computer desk but if I do, I'll need a new, larger desk so today I doodled out the above after being inspired by something I saw while doing my morning trolling. The top is 5 feet long and 30 inches wide. It 'floats' an inch above the top of the legs which are slightly tapered toward the top. There's a small chamfer on the bottom of the legs, too.
The top actually sits on three cross rails that are dovetailed into the front and rear aprons
The drawer was a bit of a challenge because I wanted it to look like it is floating under the desk. I ended up with a suspended horizontal panel that fits into grooves near the top of the inside faces of the drawer.
If I can find it, I'm thinking the desk will be made of Alaskan Yellow Cedar. I'm wondering about impregnating the top with epoxy to make it harder. I think if I could heat the wood so the epoxy would be drawn in (a method used by Robb White when he was building boats of yellow poplar) to the wood instead of laying on top I should end up with a nice surface.
