devonwoody
I have been making boxes over the past two years with mitre corners and this time I thought I would have a change.
However things did not go so smoothly for me as in the past.
The timber finished up 8.5 mm thick after forgetting to check that my bandsaw fence was square to the table so I had to thickness timber down to this measurement.
Next problem, I have not cut any dovetails for over 18 months so these were a bit gappy.
The timber used was black walnut, and had been laying under the bed for two years awaiting a project that I thought would warrant use of expensive timber. I must admit disappointment with this wood, it is very course, and does not have a nice finish after coming off the planer.
After gluing up the box I considered filling the dovetail gaps with sawdust and pva glue but decided to put bracket at each corner also utilising the brackets as feet and also top closure supports.
Next problem was gluing, the white pva glue allowed parts to slip whilst clamped up and so I had to take off the corners remake some more corner pieces and put on again.
Pleased to say though I have now completed the box as per photographs below, and will then consider some sought of finish that darkens the walnut and makes the sycamore contrast more attractive to me.
