Lin
I have a couple orders for this fretwork frame.....this one houses 7 pics.
It's getting close to being done and I took pics along the way...This is the hardest of all the fretwork frames I have done so far.....If you woodworkers see any thing in my process that would help me shorten my time or just make some of the steps a bit easier....please holler out and tell me. I would appreciate any tips and hints to make these easier to cut and assemble. I will post three or four pics at a time to give time for quetions or tips....and also so I don't get mixed up on what I'm doing. :wink:
The beginning: Frame is 17" x 17" with out the base.
First pic has 179 holes drilled...93 cuts made in the 1/4" oak overlay
Second pic has all the frets and hearts and ovals cut (264 cuts total so far) and has been attached to a piece of 1/2" walnut and lines drawn inside the hearts and oval before making outer cut to make rabbet for pics to be held in.
Third pic is after the outer cut has been made and the base pattern has been layed out on a 3/4" piece of walnut
Fourth pic is showing the base being cut at a 15 degree angle...cutting a 20" piece of 3/4" wood at that angle is a pain to do.....I always end up with bumpson the short sharp curves.....glad they made sandpaper.... :?
Will post more tomorrow.
Lin
Lin
