Argus
I'm hoping to gauge the consensus on sharpening an old saw. I don't have an issue doing the job, it's just a case of trying to work out the best sequence.
Here's the scenario: I have a good quality but old (Victorian) steel-back saw that I'm refurbishing to put to use. It's in good order for its age except that a previous user has, to put it kindly, done an inexpert job with the file to the extent that the teeth are all over the place, no set, big ones, small ones, in short, blunt and disfigured. Underneath all this, there's a lovely little old saw waiting to get out.
I'm not intending to alter anything, to restore it I've decided that it's about 11 point Rip; it isn't bad enough to need a full cut and strip but I can do a re-file, restoring the correct pattern with a combination of a gradual jointing along the length and Paul Seller's junior hack-saw trick to define the gullets and then refiling. This hack-saw business is a fiddle but has the advantage that I can avoid a lot of premature file wear at the apex of the files and use older files that are good on their long sides for the preliminary cutting, then finishing with a decent 4 inch XX slim file to set the the gullet.
That's the idea.
My query is about the set. When is it considered best to restore the set?
At the end of the job, last thing, when all teeth are sharp?
Or to set them after defining the shape of the teeth but before the final pass with a sharpening stroke?
I'm inclined to the latter, but I'm interested to hear what others may think.
(I usually complete the set with a light wipe along the edges with a very fine stone, but that's me!).
That's the idea.
