tidalcreations
Jumps......Thank you for that! Its crystal clear now. I was confused about the expansion mode...actually about it all...expansion, compression....length of spigot in the throat of the chuck. I was only concentrating on getting a 5mm dovetail joint....I thought that would be enough to hold it. Like you say...its dependant on different factors. I had been reading the manual when you replied. Seeing the pictures helps massively...lol. I shall print them off!
Thanks so much for taking the time in helping me understand
Thanks Woodspoiler. I wasn't offended. I knew deep down it was beyond my capabilities and needed to be told to step away. I get frustrated when I can't grasp something quickly. I used to have the patience to sit and work on a drawing for 30hrs, mastering different techniques....but I suppose there is a massive difference between holding a pencil to paper as to watching a piece of uneven wood spinning furiously with a rusty gouge in hand :shock: Little steps I reckon!! And taking onboard all this wonderful advice on the forums. I have a lot to learn....and being patient is one of them
