Paul Hannaby
tidalcreations":qg0avb74 said:Hi Paul H.....Yes the grain is running parallel with the bed. I guess thats why I didn't get a tight purchase with the screws? I did try and angle them slightly. I can't cut my own blanks at the moment so am limited to what I have....thats another thing I have to address.
Hi Jane,
No problem with using parallel grain blanks but in those situations and yes, you're right about the screws not holding so well in end grain (one solution to this is to drill and plug with some cross grain dowels so the screws hold better.
A bowl gouge used in the conventional manner is not the best tool for the job when hollowing end grain. You would probably be better off using a hollowing tool and make your cuts from the centre to the edge rather than vice versa. You may find this easier to do by drilling a hole in the center of your piece to the depth you want to hollow it to.
If you don't have a hollowing tool, a round nose scraper can be used or even a fingernail grind spindle gouge rotated by around 60° anticlockwise so the cut is taking place roughly from the centre to the front of the left wing of the gouge.
