8mm collet for Makita 3612 Router
Speaker
UKW Supporter
16 Nov 2020
Hampshire / Sussex
I’m hoping that the collective wisdom on this forum will be able to help me define the question to get what I need.
Background: my Men’s Shed have a Leigh Super 18 Dovetail jig with a set of 8mm shank Leigh dovetail cutters.
To use with the jig they have a Makita 3612 router with a guide bush insert.
The problem is that the collet on the router is 1/2” (12.7mm) and the cutters are 8mm.
We do have a 12mm to 8mm reducing sleeve but that is too loose.
the obvious solution would be to use a 1/2” to 8mm reducing sleeve - does anyone know if such a thing exists? And yes I have tried all sorts of searches but have not been able to get a definitive answer (I did ask Makita but am still waiting for them to call).
Another option might be to get an 8mm collet nut for the router, but again I have not been able to establish if such a thing exists.
If anyone can help with the question I need to be asking to get some clear answers for either of
these options I would very much appreciate it.
or, if there are any other options you can suggest that would be great as well.
Thanks,
Tony
I have a Makita OEM 8mm collet for my Makita 3620 (and use it often), but the 3620 is 3/8" max, not 1/2".
Cheers, Vann.
