73 x 48 mm timber - no longer made?
Mjward
UKW Supporter
18 Jan 2022
Yorkshire
Long story short - renovating Edwardian house, have several existing studs that are 73 x 48 mm and need to add just one more to the row so I can board either side, i.e. needs to exactly match the 73mm depth (the 48mm doesn't matter so much).
However, I am unable to source it, closest I am getting (sawn dimensions) is either 75 or 70. Now 2-3mm off for a single stud isn't the end of the world and will most likely go with the 70mm and add some packers but just wondering if its an old/no longer cut dimension? my table saw is currently inaccessible otherwise this would all be moot :)
Old studs tend to be very uneven, it was probably sawn at 3" and has dried and shrunk a bit. Regularised timber makes site work much easier now.
you only need to take off 1mm each side of a 75mm piece, I'd take a hand plane to it.
