gasman
My front door is pretty cr4p - lots of problems and its a bit warped. Theres some rot in part of it and I thought it can't be that difficult to make a door - especially after getting a quote from someone who wanted £1600 for a bespoke hardwood 6-panel door....
Here's what needs replacing:
I want to replace it like for like and paint it a similar colour in and out.
The door size is 1960x760x43mm ballpark, the rails are 100mm wide
I have enough meranti to make it
Can I ask some questions just because I haven't done this before and can't find on google any sensible plans etc?
I have no problem doing through mortices with wedged tenons for the rail and stiles.
I have a spindle moulder with a 40mm block and a decent router table with raised panel bits. I was planning to make raised panels and have them in grooves - would the grooves be maybe 19mm wide?? How deep would the grooves need to be? 12mm? - and the panels will be a few mm smaller than the overall size?
The inside edges of the panel rectangles of my current door look they have a moulding of sorts. Is this likely to be a separate moulding which has been added after the basic door structure has been finished or are there door jointing sets for 44mm doors similar to the kind of set one can get for cabinet doors on a router table? If so then they must be for a spindle moulder I imagine - and that would need a 50mm block and cutters?? I can't really see anything similar to what I am describing on the wealden website but maybe I am looking in the wrong place?
Sorry to ask basic questions but many thanks anyone for some help. If anyone knows an online resource which shows what I want that would be great too.
Cheers Mark
Cheers Mark
