3mm aluminium possible to cut a slot with a router
Lazurus
22 Sep 2017
Norfolk Broads
as the title says I have some 3mm thick aluminum bar which I need to cut a slot in some 300mm long and around 6mm wide, would this be possible with a router, or is it going to be a hand saw and file job.
I thought about drilling a series of holes then tidying up with a router, is this a safe a satisfactory method or should I get it machined?
I cut a 1/2" slot in 10mm ally with a slot drill in a hand held router just doing shallow passes, and did a 1/4" round over with a 1/4" router hand held in the same ally.
Both where easy when using the slowest speed.
Starfish preamp by Pete Maddex, on Flickr
Seconding Pete.
I've edge trimmed 18mm thick ally plate using a cheap B&Q 1/2" router with a carbide wood bit. Slotting is fine too. Just use guides to stop you biting in too far and take many light cuts with the speed dialled down.
I don't make a habit of it but as TC is far harder than aluminium I see no problem with the judicious use of woodworking tools and blades to cut aluminium. I sized the same ally plate first with a circular saw (dialled down to minimum speed) again taking it nice and easy but keeping it moving.
The aluminium-cutting router bits sunnybob links to are single flute - personally I'd worry about using that geometry for slot cutting. As Pete says, a slot drill should work fine - if you're OK with 1/4" then an imperial slot drills with 1/4" shanks are readily available, so would fit a standard router collet.
Something to bear in mind is that these are 'upcut' bits, so tend to draw the work into the bit. This can be a problem with thin materials . You need to make sure that the work is held securely. Sandwiching between sheets of ply can be helpful.
Personally I wouldn't bother chain drilling before making the slot. My own experience is that doing so actually makes it harder to get a nice parallel slot.
Robin.
