Ah the joys of really small stuff. I am very much into watches, but one thing I don't have the kit for is repairing broken pivots. I have to take them to a friend. Problem is scale, having to drill a hole maybe 0.2mm in a balance staff 0.7mm in diameter, and that's a big one! He has the proper watch making collets and a gadget that looks a bit like a dividing wheel, so you place the relevant sized hole over the end of the staff to act as a fixed steady. Then square the broken end and drill into it for a new pin to be inserted. I was surprised to learn that the standard technique is to use a graving tool to make a centre in the end of the shaft to start the drill, then use a spade bit to actually drill the hole. In many cases you have the added complication that the pinion was hardened, and this obviously tends to spread to the very end of the shaft below it. In this case the shaft has to be annealed before you start. It's surprisingly easy to do with the correct tools, and very satisfying. So far I have done some clock ones, much bigger, but really do need to get the kit to do my own watch sized ones. Unfortunately I think the boss lady would need some persuading to see it as a worthwhile expense.
