dvddvd
I'm trying to drill accurate using a drill press with a 2mm drill bit.
On the point of entry you see the drill bit bend a little until it get going, seems to slip on the surface.
It was just a test using HSS drills I had so will get some brad point ones to see if they are better.
The hole is only 15mm deep so would it also be better to cut the bit down as at the moment around 35mm is stuck out even with it pushed all the way into the chuck
thanks
thanks
