quintain
I am looking for a 1st fix nail gun, either UK mains or battery NOT air powered everything considered, used, reconditioned, new even ugly as long as it works and the price is low.
You can become a Supporting Member or just click here to donate.
Thanks TheUnicorn,a few options on gumtree.com, including a paslode for £70, which 'needs servicing', bit of a gamble.
Yes about hiring, 1hr ago I checked locally £20 a week I supply gas and nails for paslode.Yeah Richard like most things there's a compromise, I couldn't justify buying one now I'm retired but am pleased to have it when needed. If you only need one for a few days is it worth checking out hire cost?
that seems a very good price, I'd do that, as it doesn't sound that you can justify the cost of a new machine and it is pot luck what will come up usedYes about hiring, 1hr ago I checked locally £20 a week I supply gas and nails for paslode.
Probably that is the way I will go BUT if I see a gun at a giveaway price I will be tempted.
Best Regards
Richard
Price is now hardening up:that seems a very good price, I'd do that, as it doesn't sound that you can justify the cost of a new machine and it is pot luck what will come up used
Thank you...will a battery only which I would prefer give the 'clout' I occasionally need for 3" + nails.The other thing to bear in mind Richard is that the fuel cells on a paslode have a limited life and the gas can go stale causing misfires or no fires. So given your anticipated usage if I were you I would seek out a battery operated one. You might find it more cost effective to buy a 'body only' and then buy a 4 or 5 AHr battery. Given your short bursts of usage one battery might be ok. I have a paslode that I've had for years and it is extremely useful but I would opt for a battery powered one now just because of the gas. But check the weight of battery operated ones, I've heard the Dewalt is a bit of a brute to hold in position.
Today's li-on batteries are pretty bomb proof. I've had the same 1 x 4Ahr and 1 x 5Ahr Dewalt battery for years, they have a charge meter on them that tells you if the battery is close to running out. After hundreds of charges they are still performing as well and don't lose their charge if not used for a good while. I'm not sure if you can get a mains operated first fix gun, I've never come across one.Thank you...will a battery only which I would prefer give the 'clout' I occasionally need for 3" + nails.
But would the battery die a total death on me with my limited use.
I would consider a UK mains operated nailer if such was available.
I realise I am being a PIA to a lot of helpful people on this forum.
Hi...I think !!!! GAP Plant & Tools Hire - Whitehaven, West Cumbria.That’s a fantastic rental price & would make it an easy decision for me. Unfortunately my local hire place (HSS) charges £72.36 including VAT per week and can’t supply gas / nails. The only place locally that seems to stock gas is screwfix at £35.29 for 2. At your local prices I’d bite their hand off for my infrequent use! If you don’t mind me asking, is it a national chain you’ve got a price from?
Let me tell you a story.Today's li-on batteries are pretty bomb proof. I've had the same 1 x 4Ahr and 1 x 5Ahr Dewalt battery for years, they have a charge meter on them that tells you if the battery is close to running out. After hundreds of charges they are still performing as well and don't lose their charge if not used for a good while. I'm not sure if you can get a mains operated first fix gun, I've never come across one.
Having said all this a lot of trades people are selling their paslodes as they're moving to cordless now, so you might be able to pick up a paslode 350 a lot cheaper and take the risk of having to replace a partly used gas canister say once a year (depends on the use by date on the canister, a lot of sites state this date on their adverts, Screwfix ones always seem to have a 2 year life but you should always check). Paslodes fire up to 90mm which is ideal for first fix framing work.
I understand your scepticism but battery technology has moved on a great deal since then! However I don't think you will find one at the price you want to pay anyway, that's why I'm suggesting a 2nd hand paslode. If you do find a cordless 1st fix for not a lot of money it may be dodgy!Let me tell you a story.
Once upon a time a (not so) elderly (perhaps not so) gentleman owned a villa in Florida.
He carried out all his own maintenance when he and his wife visited annually from Sep to Feb each year.
He bought battery drills and each year the battery was bug**red when he returned and tried to use it, he bought a cheap mains drill and never used a battery drill again in Florida.
BUT perhaps batteries have improved since he and his wife sold the Florida villa 10yrs ago.
That was my history and concerns about an unused battery not frequently used.
Again thank you and all others for your help.
Best Regards
Richard
