Brian, this is a workbench alteration I did a few years ago.
viewtopic.php?t=66699
It's a simple construction (see sketchup pic) and is pretty much put together like studwork. A long top and bottom and short bits screwed in between. It's had 50 hours a week minimum for nearly 4 years and before the alteration another 9 years. Really rough and ready construction with ply top but it's rock solid [WINKING FACE]
Coley
Try this design:
You can check it is square by measuring diagonally from corner to corner and making the two diagonals match.
    55.4 KB
Ah, OK. I was going to suggest a design similar to the one I'm looking at which uses triple laminated cls for the frame - that way mortises and tenons are created by having the middle cls shorter or longer than the outer two. It makes for a very solid bench, but you need a lot. You'll use about 15 of them for the top, assuming you're standing them on the short edges
Perhaps a design similar to the one above is best then :)
Brian, look at this thread
I made it OK -- for top, redwood PAR 3 x 2 is fine. Legs I bought 4 inch x 4 inch redwood
Cut the rebates with table-saw; m10 coach-bolts to hold it together
Got some good build advice on this forum
Solid as a brick Karzi :lol:
I've just made a fabrication bench from old bits of CLS and a piece of packing ply that came with my last order of birch ply. It's exactly the same as the picture in MrTeroo's post. Very quick and simple to do.
I'd suggest you don't need a full 2.4m long bench for piecing your work together, so cut them all in half. now you've got 30. I also don't think you'll want a narrow bench like most make or a heavy top, unless you are planning on more than layup work and the occasional bit of other woodwork. with that in mind.
14 glued on the short side will give you around a metre depth at 1.2m wide, close enough to a square to be considered a useful layup table (which is really what you want, especially for a lifesize eagle). you've got a choice here, through tenons or screwed legs, for me I'd go through tenons because you can make them easily while you are glueing the top (you can get clever if you want and make wedged tenons by cutting a angle on the hole sides, but you don't really need that). simply cut the second piece from the edge before you glue it leaving a mortise once it's all glued up, do this at each corner and leave a nice overhang, about 100mm should work. great, now you've made the top lets make some legs. 3 pieces glued together will do nicely and be rather sturdy. again you've got a chance of an easy mortise by cutting it before you glue, be silly not too. that leaves you with 6 peices left to make stretchers and rails, front and back, both sides about 100mm from the bottom of the legs for the front and back, just above that with the sides. if you've gone with mortice and tenon you'll need to cut those on top of the legs, they don't need to be fancy and can be done with any saw you've got to hand. same with the rails. glue it all together, flip it over and call it a bench. then spend an age with a scrub plane, jack plane and scraper to get a perfect flat top, or chuck a piece of MDF on it and call it done. :)
something like this, only short and square rather than long and thin.
