wabbitpoo":1zgmgoqz said:I know you can get a sleeve which lets you use a 2MT in a 1MT lathe, but can you get the opposite? Don't wish to buy a new pen mandrel if I don't have to (unless it'd be cheaper than a converter)
TEP":3rgvxtbm said:Wish I had seen this thread earlier.
Now this is just for future reference of anyone who need some of these bits and pieces. I always look at the Proops Bros. site for any bits like morse sleeves and chucks, and stuff like that.
wabbitpoo":qem31se0 said:As someone said, Axminster only do a sleeve for using 2MT in a 1MT lathe.
CHJ":1ck2xerx said:wabbitpoo":1ck2xerx said:As someone said, Axminster only do a sleeve for using 2MT in a 1MT lathe.
:shock: :shock:
I think you need to check that fact a little more.
A No. 1 Morse taper has a Guageline (major) diameter of 12 mm
A No. 2 Morse taper has a Guageline (major) diameter of 17.78mm
Most lathes with a No. 1 Morse taper would not even have big enough spindle diameters to accommodate a No. 2 morse taper.
http://quest42.co.uk/metal/files/Cone_Morse.pdf
Using an extension adapter to enable use of N0. 2 morse tools in a No. 1 morse socket is OK for occasional use only IMO to avoid having to purchase multiple sets but it is mechanically undesirable.
wabbitpoo":3f6aa3e6 said:.......I have sourced one now though. I used rdg tools. £11 delivered. Thanks to all for your help.
wabbitpoo":2qywpc2b said:Thanks for that tip. Some people seem confused as to what they think I want. I wish I'd never mentioned it now! The thing is on its way, so maybe I can put this to bed!
