My daughter has given me a nice challenge to replace a drawer divider in a pre-owned piece of furniture that is a missing a drawer divider. All very simple - 300 x 60 x 7mm until you come to the mount which is steel pins in the drawer carcase that you slide the divider onto, with a stopped 1.5mm wide x 5mm deep slot in each end of the divider. The pins are clearly less than 1.5mm, as I have measured the slot width in the sample divider I have brought home by seeing what size of drill bit fits tight into it.
I'm guessing that the originals were made with a suitable saw blade mounted in the equivalent of a router table.
On the basis that my daughter is not demanding an exact replica - ie it could be glued into blocks - and for a one off there is little encouragement to spend money, can anyone suggest a way to do this.
Rob
Rob
