WIP - Small Bullnose Plane
Crooked Tree
29 Nov 2009
UK
This is actually a "work complete" posting, but as it was a Christmas present for my father and I intended to make another one for a user of this forum, I decided not to post until after the big day.
The plan was to make a small plane using available materials (brass and wood). I decided upon a bullnose because he does not have one that works. Originally it was going to be a riveted brass-wood-brass sandwich, but I was inspired by posts on this forum (mostly the impressive Aled plane kits) to try dovetailing a brass sole. As I had never done anything like this before I made a prototype/concept demonstrator first.
Materials prepared: brass bar from an offcut; oak stripwood; 2nd hand stanley 2" plane blade cut in half (had to use a tungsten carbide rod blade when I got to the hardened bit) and ground on a bench grinder.
Dovetails filed
Initial assembly - this took some hammering/squeezing with a vice.
Peened... and what a mess! Didn't think I would be able to recover this.
Looks better with some filing.
Cutting the wedge
Shaping the wedge
No pictures of the riveting through the oak infill - I was too ashamed by the mess I made. It took many hours and 2 sets of rivets. I think the problem was that I drilled too large a countersink for them, resulting in their crumbling with my attempts to spread the end such as to fill the countersunk hole. This resulted in a few pock marks in the plane sides left by bits of brass which broke away from the rivet heads.
Finished! Just in time (Christmas eve).As you can see, it has some faults: pock marks from dodgy riveting; sides not quite square to base, even after much filing; nose must be removed to sharpen the blade; wedge needs to project further forwards on the blade. These may be improved upon when (if) I find time to make the Mk2. This time I felt that I was going to make things worse if I made further attempts to rectify the faults.
Having spent far longer than planned making this, there was only one recipient on Christmas day.
My father seemed pleased with it, which is the main thing.
I know this much... I wouldn't know where to start with this peening; or whatever it's called. So don't put yourself down! If it works, it's a good 'un!
John :ho2
Although I've never done it, most of what I've read seems to suggest peining looks like a disaster until you start filing, so I think you're OK there.
Any chance of a bigger pic of the finished plane?
Ed
Here is the bigger picture - I did an edit on photobucket and saved over the original. Doh! :oops: There does not appear to be a rename option.
Trouble is ... everything we build/make the first time tends to be a prototype, what with all the new skills to be learnt etc.. That one looks great from here, and self designed too. Very well done, very well done :)
xy
Thanks very much, most kind. I am actually quite proud of it.
Made a couple of tweaks today - ground the "tang"(?) of the blade (the long thin bit going through the body) a bit thinner to allow for some lateral adjustment and re-sharpened the blade slightly more square so that less adjustment is required.
CT, till I retired I was an engineer, and with plenty of workshop practise under my belt, stop denegrating your effort!
That's pretty damn good and I know difficult that job is and is why I make my planes out of timber!
Well done mate!
Roy.
hi
don't put yourself down like that , its a good effort really , only one small point why the pan head self tappers in the end ? hc
The machine screws in the front hold the nose piece on, making it a removable-nose bullnose plane, so that it can be used right up into corners. I also thought that this might be easier than dovetailing the nose in place.
They are stainless steel machine screws, M3 pan head. I would have preferred cap head but this was all that I could get from the DIY shop at this size. The design evolved during making, resulting in the screws being tapped into the plane sides for strength, with the trade-off that they could not be sunk into a clearance hole (too close to the edges). The original plan had two screws on the centreline but I was not convinced that they would hold well enough in the wooden infill.
Excellent work CT!! The buzz gained from making your own tools is pretty amazing eh? !!
How about adding a little chamfering around the top edges to add a little decoration? Konrad Sauer blogged a while ago about adding chamfers, and how subtle details could change the look of a plane. His website is really worth a browse if you've not done so already.
http://www.sauerandsteiner.com
I'll try and find the post on chamfering, and add a link if I'm successful.
I have some M3 countersunk Stainless Steel screws if you want a few. I bought a pack of 50 for making my Secret Santa gift and have only used 2. Send me a PM if you'd like them.
Aled
Edit : Here you go, the stuff about chamfering is about half way down the page.
http://www.sauerandsteiner.com/news/2007/03/nutsbolts.html
I'm sure there was more somewhere, but I'm yet to find it.
John :ho2
It really isn't as difficult as it seems, there isn't any "magic" involved, just a couple of whack wiv an 'ammer.
The instruction manual for my Small Shoulder kit goes through the whole process in some detail. PM me with your e-mail address if you're interested and I'll send you a copy.
Aled
Thank you John, thank you Aled. It is pretty satisfying. I foresee a danger of spending all my time making tools!
There is in fact a chamfer on the top edges, initially added to prevent cuts. Thanks for the link - perhaps on the next one I may try something more sophisticated as per the examples.
Here is a picture from a different angle showing the chamfer. A bit over exposed, but you get the idea. This was done by hand, by eye, with a file.
Thanks for the kind offer of the M3s. It may well be a while before I get on with the next one, so I shall not relieve you of your stock yet but I shall bear you in mind as a possible source closer to the time. I plan to finish a woodworking project that I have had on the go for months first - I may post it soon.
