transatlantic
Boom!
Just received mine and I am really enjoying it. Super expensive for what it is, and now the most expensive thing in my shed, but I think it's a fantastic product!
I've managed to sharpen my bowl gouges (standard grind) and roughing gouges very easily with the V-Block. I've also now got the hang of using the finger nail profiling tool, using this video :
https://www.youtube.com/watch?v=SJ8TOkRoqYo&t=523s
I was trying to do it in one sweep initially and grinding too much of the tip. But using the 1-2-3 method (as they call it), am now getting very nice results.
Still haven't mastered skew grinding yet. I'm a little shaky with it, so that needs more practise.
I'm wondering how to sharpen my spindle gouges though? To get a grind like the following :
Not sure if I should be using the V-Block, or a specific setting using the finger nail jig ( I also have the long grind attachment)
All in all, great bit of kit! would recommend. Here are my niggles with it though (considering it's a very expensive machine)
- I feel the belt should be about 2" wider
- Angle adjustment of the belt and rollers should be quick release
- The table could do with being a little bigger, with chunkier jigs (the skew jig for example is very thin)
- Having to unscrew the table each time to remove it for finger nail profiling is annoying. It should be quick release
- The belt guard should be quick release
- It would be much easier if the motor was behind the belt, so that there is no obstructions from the left side (My small tools bang into the motor)
- The instructions on the front should not be a sticker!
- Angle holes should be labeled!
