Sheet Velcro Abrasive cutting
CHJ
31 Dec 2004
Cotswolds UK
Being a one for watching the pennies I cut my nominal 50mm pads from sheet stock.
Having spent half hour this afternoon sorting some of the spare stock I thought folks might be interested in how I make sure I don't skew cut and end up with that remaining strip that's just a tad small for the pad.
Always one to measure once and for all and make a simple jig, I made up a simple marking sheet out of a bit of Plexiglas.
To do similar with Plexiglas or Ply mark out your sample abrasive and use this to drill a series of small pencil guide holes in the template.
Use the template to spot through to new sheet with a pencil.
If you want, join the dots.
I store my template in the abrasives bin.
The front lift out flap just stops too much debris finding its way in, it's close to the headstock.
    61.6 KB
    72.7 KB
    98.1 KB
    87.3 KB
    115.3 KB
You're way too organised Chas :lol:
I bash mine out with a punch and lump hammer (hammer)
Might try cutting them square next time though as I have read that there is no need for them to be round in practice ?
Cheers, Paul
That's a great idea. I always try to buy mine in the 150mm wide strips as I find that I can get 2 x 75mm, 3 x 50mm or 4 x 37.5. so I could see a template like this being very handy.
Below is how I cut a .5m x .150 sheet
In fact Paul, when abrading inside boxes and bowls the 'wings' seem to offer an advantage at times.
And even at times the four corners of a 'used' piece can be beneficially used to get in that odd nook or cranny.
