Doctor
Hi,
As promised heres how I run MDF doors with a single router which never needs adjusting.
The router is mounted in a table, the cutter is a 9mm goover, 9mm space, 9mm groover we use a bearing but its not necessary.
The fence is set to the appropriate depth of cut, ie, 12mm or 15mm or 18mm whatever depth you use.
You'll see that the fence is set so there is a 9mm gap at the bottom (like a groove).
The height of the cutter is set for running the tenons.
The tenons can the be run with the guard in place, we use a guard that is adjustable and can be locked at any height by toggle clamps.
Then to run the groove we just insert the 9mm false bed which locks in place by sliding into the 9mm slot at the bottom of the fence.
Once set up we can run 25mm or 22mm doors without altering anything, and the guard is adjusted accordingly.
It works because we use a false bed the same thickness as the door panel.
You can see I have marked each bed up "tenon" or "groove" face down to make it fool proof :lol: :lol:
This set up saves me loads of setting up time, a door can be run in 2 minutes easy.
Hand made kitchens herts
