I've been thinking about shooting board design and was considering building a ramped version. They do have the advantage that the wear is spread over a region of blade so one is more likely to be using a sharp edge.
However, the other advantage often claimed is that they simulate the action of a skew blade. I think this argument is incorrect. A skew blade, (or a skew motion of a straight blade in normal planing), attacks the wood fibres with a slicing as well as a pushing direction. It is well known in engineering cutting theory that this gives a faster cut with less effort. When carving your turkey be sure to make a rapid back-and-forth motion as well as pressing down. But this is not what ramped boards do. They are still pushing head-on to any individual fibre and not slicing it. It is as if one skewed a straight edge plane and then pushed in the direction of the axis of the plane rather than along the length of the wood. Planing in a diagonal direction as in flattening as bowed board, is not a skew motion unless the plane is skewed away from the direction of planing.
To properly simulate a skew plane with a straight-edged plane, one would have to build a carriage to hold and tilt the plane at an angle to the horizontal, then push this carriage horizontally on a normal shooting board.
Has anyone using a ramped board done any comparative tests, side-by-side against a normal board?
Maybe this sliding ramped carriage is worth building! Not too hard with a dedicated woodie, just screw it to a wedge.
Keith
Keith
