First off look at these diagrams of switches, and the page they're from (click the picture):
Your planer had a
double-pole, single-throw, normally-open switch. That means it was normally off ("open") and, when you squeezed the trigger, it connected both live and neutral connections to the motor at the same time. When you let go, both were disconnected.
So, as far as I can see from your pictures, your switch was one of these:
It's electrically the same as a pushbutton, but I'll stick with the actual switch symbol as it's easier to work out. The dashed line in the symbol means that both "poles" of the switch operate together - the "wipers" are mechanically connected together (but not electrically!). You really need something similar as a replacement. The planer will
work with a single-pole switch like this:
But it won't be completely safe. This is because, in the UK, 110V tools are used with a centre-tapped isolating transformer. The unswitched wire, which would be a 'neutral' if it was a 240V tool, is always at 55V potential with the metal case of the tool. So when the planer is 'off' there would still be 55V on BOTH wires to and from the motor. It would make you jump if your finger got between one of those wires and the metal case.
It wouldn't kill you unless you really work at it,
probably, but it's not a safe situation. People have been killed by lorry batteries (24V). It's very, very unusual - they do more damage if you drop one on your foot mainly- but that's not the point: 55V can just about be fatal! So you should have a double-pole switch as before, to isolate the innards from the mains unless/until you push the trigger (what happens next is entirely your fault
You have two wires coming from the motor to the switch, probably both the same colour (doesn't matter), and three wires from the cable (flex) coming into the planer.
IF IT IS AN AMERICAN TOOL the cable/flex colours will be these:
Black = live
White = neutral
Green = earth
Notice that, using the OLD colour scheme in the UK, black should be NEUTRAL**, not live. That confuses people in the UK who see American stuff for the first time!
For your planer, basically, BLACK and WHITE go to one side of the switch, and the two wires from the motor go to the other, so that when you press the switch, black goes to one wire of the motor and white goes to the other wire of the motor.
If Black and white connect to each other (when you press the switch), this is what's technically known as an EPIC FAIL (or more boringly a short circuit), and may result in smoke, hot sparks, and a spoiled switch and 110V transformer.*
So check which connections are which - usually on long thin things, the switching is on the long axis. Check with a torch bulb and battery, or a meter on a low resistance (Ohms) range - they often have handy beepers so you don't need to actually look at the thing. DO NOT test it with mains.
You may only find a
double-pole double-throw switch when you shop for one. This will have six connections, because each pole of the switch is changeover: when you push the switch, two contacts go 'off' and two go 'on' at the same time (look at the diagram to see how it's wired). These are fine for your task, but you need to know which contacts are which. If it's not written on the switch, you WILL need to test it before you fit it..
Hope all that helps,
E.
*It shouldn't, but don't take the risk.
**When using a 110V yellow site transformer in the UK, technically speaking, there isn't a neutral on the 110V side, only TWO 55V live wires (giving you the 110V the tool needs). It's a little complex. The system is safer than our ordinary mains in many ways, but it needs a double-pole switch to isolate the tool completely. In the USA, tools also use 110V, but it's a live + neutral arrangement similar to our 240V one here. The motors don't care, but the human-safety arrangements for the two systems are subtly different.
