SVB
Saw this on YT - an unusual approach!
http://youtu.be/oezp-_DcUgg
(Warning - bit of strong language)
S
S
I don't have the gear to hand, but the inside of the connector for my DF700 looks quite different. Ah - here's a good image: http://www.axminster.co.uk/festool-spar ... GwodjE4IeAEric The Viking":2x08bnia said:Does anyone know - do Neutrik make the power connectors for Festool? I don't own Festool kit, but I've often thought the exterior of the plug looks a lot like the old "Speakon" connectors:
If so they're probably pretty well designed, and rewireable. Neutrik have made mains connectors that size for a long time:
(and there's a new style black/orange thing they make that's probably cheaper too).
n0legs":9lbphpnt said:Not really sure what to make of that.
Okay so he took it apart to have a look inside but I'm not sure about his assessment of the machine.
I really didn't get the bit about melting the plastic as a test or his issue about the motor housing end cap being a lesser grade of material.
What I am sure of is what a waste of a good tool if he can't get it back together.
Interesting in some ways, but gratuitous in others.
F__k_ng I_ot is my honest opinion :roll:
Eric The Viking":1idwnago said:I like detachable cables as a rule because they make tool storage a lot tidier, and they're safer when you're carrying tools around (less chance of tripping or catching the cable on something, but given I own no Festool presently, I'll probably go my own way on this, if I ever do mod any tools.
n0legs":29f1an5i said:It would have been way more interesting and informative if a Festool engineer did it and explained some of their design ideas and reasoning behind construction and materials choice.
pcb1962":22pk2p4d said:Not an ***** at all, a very knowledgeable and capable engineer.
Sporky McGuffin":2nz9jxy5 said:n0legs":2nz9jxy5 said:It would have been way more interesting and informative if a Festool engineer did it and explained some of their design ideas and reasoning behind construction and materials choice.
I'd much rather a qualified independent reviewer - the guy clearly knows his stuff and wasn't afraid to point out the good design as well as the less good.
Eric The Viking":3h9w4vak said:There's a discussion here http://festoolownersgroup.com/festo...now-about-plug-its-conversions-(usa-version)/ but only about the USA (110-120V) configuration.
They apparently sell conversion kits for other brands of tool (a power-in plug-it with a some inches of cable to go into the actual tool). This strikes me as just nasty as the plugs will keep catching on the work etc.
n0legs":16c30bgo said:pcb1962":16c30bgo said:Not an ***** at all, a very knowledgeable and capable engineer.
How do you know that?
n0legs":16c30bgo said:The one that I was interested in, the Hilti (because I own use and rate them) he didn't get back together, unless there's another video I may have missed.
pcb1962":u71y16ng said::roll: from watching his videos for the past 3 years.
n0legs":2va5vbq9 said:I think you missed my point. I wasn't after a review, they've been done to death about Festool stuff, I wanted some insight.
custard":2x0gl915 said:(on Spagnuolo)... I came to the conclusion that, nice enough chap that he appeared to be, his opinions on an expensive router table weren't anything I'd base my buying decisions on. Not that I thought he was dishonest in any way, just that his standards on accuracy and reliability aren't my standards, so he's not someone I'd turn to for advice.
n0legs":13xhlxfr said:I'll pop my videos up of me doing some open heart surgery. I'm an expert... Honest.pcb1962":13xhlxfr said::roll: from watching his videos for the past 3 years.
pcb1962":3f6wfdsl said:Your mistake is to assume that I'm not qualified to judge his level of expertise.
