Hi,
I recently picked-up a knackered little wooden razee jack plane off ebay (1.75" blade, about 12" long) with the intention of eventually converting it to a scrub plane. I've read through this thread, and others on the subject, so I think I understand generally what I have to do except for one point : the shape of the mouth.
I understand the mouth must be fairly wide to pass the large chips which a scrub is designed to take. However, in an earlier post (this one :
https://www.ukworkshop.co.uk/forums/post625062.html#p625062)
bugbear links to his archive about converting a similar plane; in the archive article he talks about reshaping the front of the mouth to be an arc which conforms with the shape of the blade arc.
I can't quite understand why, and I'm wondering if it is absolutely necessary. Would it be sufficient to leave the mouth square but wide enough to pass the shavings taken by the centre of the curved blade? What am I missing?
Chris
