CHJ
Following on from posting about Burnishing HSS Turner Scrapers in Jonzjob's Thread I dug out my home made version of of a burnisher.
I used a scrap solid Carbide Endmill as the burnishing post and because I have no means of machining a taper as per the commercial items I set it at an angle, approx. 5deg. which seems to work OK.
As I do not have alternate Burnishing post with differing angles, If I need to increase the attack angle to increase the edge pressure I place a large packing washer on the pivot stem to lift the scraper handle.
