Turning Time in 2009
Haven't you run out of offcuts yet Chas? :lol:
You are going to have to use all this expertise and make something bigger with them. A big bowl or platter or something.
No comment needed re quality etc. A+ as always
A bit of a fiddle in preparation pays dividends Paul, also I've found it pays to let the glue-ups settle for a while for moisture to equalise before turning.
Am going to move to a different adhesive though, probably Polymite, been using low creep PVA but still get movement if heat is generated in sanding etc.
..Pete
Get a new bag full ever week it seems Pete, ironically you need a decent length of wood to hold to produce accurate segments, which then leaves you with a well prepared offcut that's too good to throw away :lol: .
johnny.t.":2ndjd584 said:
..... Segmenting is something I've not tried, I can only imagine the gaps if I did :lol:
JT
Main problem Johnny is deciding a method of cutting to size (segment length) that you are able to repeat. I use a chop saw and disc sander.
Stock wood must be prepared square and true on all four sides, stock size is not ultra critical.
Most critical thing is to keep the cut surfaces flat and square to the ends.
Taper is also important of course, but as long as you do a dry run clamp-up first it's possible to do a minor adjustment on the odd piece to get a good circle.
The easiest sectioned pieces to do are like the vase and pencil pots, all alignment and joint fit is done on the lathe.
______
________Handled another little project...____Click on images for larger view.
________
________________
________
_____________Walnut & Stained Beech
Shiny and sharp Tom, :p
Haven't had time to try them out yet, steels delivered Sat, only got the handles done late this afternoon.
Hope to bore everyone with beads a plenty anytime soon.
Chas,
I have looked at those and I think Richard has one for a repeat job he does, might put them on the Christmas list.
DaveL":2ytwkjbd said:
Chas,
A bit of a cheat really I suppose Dave, there's enough tools already in a standard kit to do beads, something I tried about a month into turning but what the heck, sometimes an easier way just seems too attractive to be too PC.
______
________Another request out of the way..____Click on image for larger view.
________
________________
________
_________Ovangol_(225mm H)
Posh toilet roll holders! Something different.
Seriously, your usual quality of workmanship and finish. Not surprised you are getting these commissions Chas.
beautiful as always chas, can i just ask what finish you use, i have recently bought lemon oil, and finishing oil but i dont seem to get a shine on any of my stuff, so i often tend to friction polish everything because i likes a shine, i does, governer.. :lol:
For a simple shine wax polish is fine Steve. Friction polish has shellac in it . Most oils leave at best a satin finish, some of them a matt finish but they can be burnished after being allowed to dry. Another trick, try just using sanding sealer then burnishing on the lathe with shavings. Might surprise you
i dont know about surprise pete, it will annoy me having spent money on oils i didn't need!! :lol: :lol:
Just a quick reply while the visitors are putting the world to right.
80 % of my pieces are finished with sanding sealer, and as Pete says, immediately burnished to a hard shine whilst drying, trick is to put enough on to burnish without causing build up streaks.
Sometimes if water resistance or harder wearing required this is followed by a coat of melamine, again burnished, this requires considerable practice to get right. Cutting-polishing with burnishing cream can enhance this finish considerably if required.
If gloss required on limited handling items then I use Woodwax22.
High gloss is normally carnauba wax applied via buffing system, the last few items are examples.
