chaoticbob
I have Axminster 'Hobby' machine which I bought maybe 7 years ago for a specific job. It did the job (internal cutouts) but I got very frustrated because it takes only pinned blades, and at the time I couldn't find much of a range - much more variety with unpinned blades. So I bought 'adaptors' (probably from Axi) and a load of Pegas unpinned blades. The 'adaptors' are just barrels of metal with machine screws at each end which you tighten up to grip the blade. The problems with this arrangement are: (a) the screws mangle the blades making them liable to break, (b) the 'barrels' are so bulky that if you're doing small cutouts you have to take one off to thread the blade through the work and further mangle the blade when re-attaching ,and (c) the bulkiness of the adaptors means that the effective length of the blade is reduced to the point where it becomes a struggle to fit it between the arms.
I now want to make some cutouts in 6mm ply with maybe 2 mm radius curves. Any advice on either suitable pinned blades or a better adaptor which would allow me to use my Pegas blades without going mad?
Robin
Robin
