Can someone advise me on the relative merits and otherwise of sanding with:
handheld abrasive;
using a rotating disc with a handle (like this - http://www.ockenden-timber.co.uk/index. ... ts_id=1688);
using a powered disc (attached to a cordless drill) as the piece rotates?
According to the link the second one helps do away with sanding lines that follow the direction of the wood on the lathe. Does this work, and what would having a powered sanding disc add to that (I've watched videos of people using the latter).
Chris
handheld abrasive;
Chris
