Hi,
I have a Fox F46-717a lathe, there is a problem with the manual variable speed. When I push the speed lever it is stiff to push but the speed does not increase, in fact the spindle slows or stops an has no torque. I removed the cover and when pushing the lever to speed the drive wheel it opens/widens (normal I believe) and the (new) drive belt becomes loose and the spindle looses torque. I pull the lever back the back in the direction to slow the spindle and the drive wheel closes and the belt tightens and I have torque. The motor does not sound like it is changing speed during this exercise. I wonder if the motor is knackered or if hopefully it's a less serious problem. Does anyone have any suggestions?
Mark Tooke
Mark Tooke
