Autumn Challenge.Place ONLY your entries here. (no comments)
Status
Not open for further replies.
Grahamshed
14 Apr 2012
Oxfordish
Time's up ladies and gents.
The Autumn Challenge was for a ‘Pierced turning’. Paul Hannaby has kindly agreed to judge this quarter’s Challenge,
Challenge Requirements:
The Autumn quarter’s rules were:-
1. The Challenge is open to anyone and everyone.
Entries must be new and made specifically for the Challenge.
2. Entries must be made of wood which must be turned on a lathe using woodturning tools.
3. The object made can be of any type, size or shape and for any purpose but must be pierced with multiple holes.
4. Carving, colouring, pyrography and texturing are allowed for this challenge. However, the judge must be able to see your turning and piercing skills!
Please post three images of your work together with details of the wood used, the tools and methods used to make it and any key dimensions.
1 showing a general view of your entry .
1 top view of your entry
1 view of the bottom of your entry
A fourth picture may be added (but is not compulsory) if needed to show any other interesting details of your entry.
Image size - please use image size 640 x 480 0.3mp, as in previous challenges
Please upload your pictures and description here’ between 10pm on Friday the 23rd September and 10pm on Sunday the 25th September.
Please also send me a PM giving me your own opinions of 1st, 2nd and 3rd places amongst the entries (other than your own) between 10pm on 25th September and 10pm on 27th September (for me to compile the entrants’ scoring).
Good luck to all.
Here is my entry.
It is a lidded box with a pierced lid made from a 76mm square of lime. I turned the box on my Axminster AWSL1000 lathe using a roughing gouge, spindle gouge and two scrapers, 1 square and the other round nose.
I drew what I hoped would be a pleasing pattern on the lid and pierced numerous holes with a drill to facilitate my scroll saw blade. I then cut out the pattern with the scroll saw and then used a Peter Childs pyrography iron to make the leaves come alive.
I sanded down to 240 grit and then went to Yorkshire grit before giving it a coat of Liberon Black Bison Wax.
Size height 45mm dia 72mm
    50.7 KB
    30.2 KB
    46.7 KB
    65.5 KB
My entry is an earring stand made out of Yew, it measures 195mm tall x 125mm at its widest, the tools used were a 1" square end scraper, a 3/4 skew chisel and a 3/8 th spindle gouge, The finish was cellulose sanding sealer and microcrystaline wax. The green baize is stuck to the base to protect the base but also to cover the screw chuck hole which was plugged. This stand was made in 4 parts, first the base which had a hole drilled in the top to receive the tenon on the column which was turned second, then the earing shelf was turned, then the finial which had a tenon on to go through the earring shelf and into the column.
    178.5 KB
    207 KB
    179.2 KB
Sorry to disappoint on the quality, Bobajobob.
My effort is two things;
1. A rush to get something done before emptying and dismantling the garage/workshop ready for a rebuild, and
2. My first ever 'pierced' work.
A Magnolia bowl, 130mm x 45mm. Part turned fresh from felling, then returned to final shape. I used my bowl gouge for all shaping and spindle gouge to make the chucking point. Parted off with parting tool. Sanded to 400 grit. 'Pierced' using all I had - several sized drill bits, set out using the lathe's indexing to try to get at least a bit of interest.
No finish as yet, because the finishes box was already packed away - Grrr!
No expectations, just pleased to have actually completed something in time.
    43.6 KB
    61.8 KB
    52.4 KB
A platter turned from a piece of old oak kitchen worktop.
13'' diameter. 105 'piercings'
The 'piercing' was done on the scroll saw.
Not sure what else to add except I love that that you can see the finger-joints in the original worktop.
Chancing my arm with this one, but I think it still falls within the rules.
I made this after a FB friend showed me a photo of one.
Fruit bowl from another piece of recycled oak kitchen worktop (yawn).
9¾'' diameter.
The piercing was done BEFORE the turning - with a Forstner bit.
Then it was hot-glue mounted on a scrap piece and turned.
... the top
... and the base
... it was set out by printing a circle template with 24, 18, 10 and 5 divisions.
I finished it with coconut oil, which has proven to be perfectly ok.
a bowl for potpourri in butternut and rosewood. started this morning and here it is. 8" by 6" high,bottom turned on a screw and then remounted on the chuck and hollowed . lid turned with the bottom mounted on the screw,then turned, then drilled the vent holes and the hole for the finial. took the chuck off, roughed out the finial between centers, including the 5/8" tenon to go into the lid, remounted the chuck and glued in finial with tightbond 2, had lunch, remounted the roughed out round finial in the spigot jaws and finished the inside of the lid. changed spigot jaws for cole jaws and remounted the lid in them and turned the finial. everything sanded to 320 and 6 coats of rattle can laquer. left the inside unfinished as always with potpourri thingies.the blonde came home from work and claimed it.
sorry bout the sideways pic, its not like that and is correct when enlarged. thx
    70.9 KB
    76.1 KB
    41.9 KB
    33.7 KB
Turned from Tulip wood using bowl gauge and sanded to 400grit then marked out using coins of different sizes once happy I used a multi tool to cut out the holes and then hand sanded down to 400 grit for a second time then given a coat of sander sealer before ebonising with a spray and finally three light coats of a gloss finish with a gentle rub between each(thank goodness for quick drying finished)
Status
