Last December my Jet AFS-500 air filter developed a fault causing the motor to run in an underpowered, sickly sort of way. Whilst the remote control commands were acknowledged by a ‘beep’ from the sounder on the PCB, the appropriate LEDs only illuminated dimly and they flickered rapidly (50Hz?).
I spent £58 on a replacement PCB from Axminster, and so far the air filter is working fine. But as the replacement PCB is identical to the one with the fault (i.e. not a new improved version) I thought it might be prudent to repair the faulty one if I can, but I could do with a bit of help please as my knowledge of electronics is rather rudimentary.
The faulty PCB is on my workbench and for safety reasons I’ve no intention of connecting it to the mains at any time other than when I put it back into the air filter to see if I’ve rectified the fault.
I’ve examined the PCB (no visible faults) and I’ve produced a partial circuit diagram showing the components between the mains AC input and the low voltage output to the logic and control section of the circuit (5 volts DC).
To try to determine if the fault lay in the logic and control section I hooked up my bench PSU to points TP1 and TP2 on the circuit diagram, set the output to 5 volts, and tested the PCB for responses to commands from the infra-red remote control and from the PCB mounted buttons.
The responses were perfect. The appropriate LEDs illuminated at full brilliance with no flicker and the buzzer ‘beeped’ in response to all control commands.
This led me to believe that a stable 5 volt DC supply was not being created by the PCB components, and so as a first stab at fixing the fault I replaced C8 – the 1,000uF 16v reservoir capacitor, to see if that was the culprit – but it wasn’t.
My gut feeling was, and is, that the fault lies closer to the mains input, and so I checked those components that I could.
Diode D1 (1N4007) works correctly.
For the time being I’m assuming Zener Diode ZD1 (5v6 1W) also works correctly.
R15 resistance is correct at 200k Ohm.
The combined resistance of R1 and R1A, which are wired in parallel, correctly measures 50 Ohms.
The fuse is intact.
The resistance across resistor VAR measures 5M Ohm, which I take to be correct.
For the time being I’m also assuming yellow capacitor C1 works correctly.
I do not know what component BF1 is, but I guess it might be a filter, and for the time being I’m assuming it works as intended.
All of which leaves the large black rectangular capacitor C2 – marked “105k 400VAC” as my prime suspect at this stage.
Unfortunately I can’t find a 105k 400VAC capacitor in the Farnell / CPC /RS / catalogues – least, not as I recognise it, and so I wondered if anyone here might know where I can get one.
I’d also be grateful for any comments, suggestions or advice you may be able to offer.
Many thanks,
Jack
The fuse is intact.
Many thanks,
Jack
