hunggaur
Hi folks whilst i have a few minutes i thought i would share what happed the other month just a word of warning.
i used to have a cast iron 12 inch whithead planer thicknesser which was a great bit of kit.
however the other month whilst using it to thickness a a piece of ash the planer threw one of the blades ( i think it must have worked lose over time and then hit a knot)
well the result of this was the blade had to go somewhere and it did at very high speed straight through the top of the cast iron jointing bed shattering it to bits.
my only saving grace was that when i got the machine it had no blade guard to protect you from the blades on top of the jointer when using the thickesser. so i has built a box guard out of 18mm MDF which i also put a dust outlet in so it was quite wide that sat on top of the machine over the blades and this contiained 80 % of the shrapnel. The rest was stuck in the celling, walls and floor.
I don't know how but it all managed to miss me (THANK GOD) all i need after the event was 2 bottles of valium, half a bottle of scotch and a new pair of underpants.
please folks check your blades are tight on a regular basis.
also has anyone else had this happen????
regards
jon
regards
jon
