Paul.J
With all the problems some Perform lathe owners are experiencing at the moment,and talk of maintaining the lathe i thought i'd give mine a bit of TLC.
Cleaned it all out from dust etc,but didn't quite know what and what not to lubricate.The manual is useless.
So i took some piccys of the workings and thought someone could point out what to do,if you don't mind.
The two grub screws on the drive shaft were loose(piccy3),so these were tightened.
The lathe as now started to develop a slight rattling noise which i can't pinpoint,seems to coming from the drive shaft by the spring:?: :?:
I can see where the grease nipple is,but what about spraying with WD40 or PTFE.Which parts need this. :roll:
Paul.J.
Paul.J.
