Jiffy Jack—- Router Lift
jonluv
13 Jul 2010
Somerset
I have just built a couple of router tables and was wondering if anyone has ever used a “Jiffy Jack” as a lift. at £10 it seems to answer a lot of questions
A car jack and a plunge router are often used when building a router table.
The scissor (car) variant is a bit of an overkill, so I imagine a smaller lift would also work adequately.
A Router Raiser is a far better purchase. This is the cheapest true router lift available.
From above ...
Used in association with a Muscle Chuck (to enable above table changes) ...
And from below the table ...
Regards from Perth
Derek
Looks great... except it is 10 times the price of the original suggestion. I think the solution is actually to use a router that already has a fine depth adjuster built in. I use an Erbauer one - cheap, robust enough for what I need and the adjuster is very easy to access from the front of the table (I don't need to bend down). I can also change the bits from above.
