Hi everyone,
I´ve always wanted to join a woodworking forum, so nice to meet you all.
I have an exterior Pine door to make (front door of a house) and frame
The Architect says the client wants solid pine. The top of the opening is arched.
The design they want is simple, normal frame shaped to the arch. The frame of the door to be normal, also having the head arched, and the panel area to be solid pine boards, the same thickness as the frame. Their orientation is horizontal and no chamfer on their edges.
So, I hope I described that well enough for you to imagine how it is. Oh and it is to be painted.
My doubts are the panel area. All of these boards are going to move a lot. What I have in mind is, tongue and groove the edges and leave a gap between the boards. I´ve heard of a spacer system called "space balls" which are used around floating panels to keep them centered. I think they are small rubber pellets or something? I don´t know if I will find them in Spain?
So, any advice on this would be very much appreciated.
Edit: just uploaded a sketch
