adidat
I will not buy anymore tools...
so i bought this last sunday and it was screwed to a piece of beech, thus usually meaning the router had been dropped and shattered and screwed down to make it usable again.
i was a brave soldier and unscrewed it. to my pleasant surprise it stayed in one piece, spent about 30 minutes with a bit of wire wool and oil cleaning of the crud to find this.
and if you look really closely, the ep mark can be seen
what it should look like
so a few minutes on the internet lead me to this on the fantastic hyper kitten website, i believe this is the image from the catalogue.
and then some further research led me to WK fine tools and Frank Scronce's very in-depth small router plane study, to find images of the real deal showing how it can be used 2 ways.
so this has inspired me to restore my one. so i need to make the handles source the bolts and source and cutter (the hard part i fear :evil: :evil: ).
heres a WIP on making the handles. for something this special i felt boxwood was my only choice and i had a lovely piece and i was itching to use it my mind was set.
mounted in the lathe
WOW! boxwood is amazing to turn it just peels off and the finish left is superb!
then i pared off my handle sections
the 2 handles waiting to be drilled and tapped
tapping them (the chuck is being hand spun)
im now drilling some brass rod to make the ferule/separator
to get both pieces the same lengths i have locked of the lathes saddle and just using the cross slide to cut the required length as the pieces where so short (11mm) i inserted a thin piece of metal for a depth stop. remember to remove this piece before engaging the clutch as it could fly out and hit the opposite wall .
cutting the thread on the spindle
all the components before the glue up, im using the original araldite
all glued and clamped up
im going to leave that until tomorow and start experimenting with my granddads rather alien looking home-made ball turning tool.
sorry for the cruddy pics i was doing it in the metal shop with poor light but i think you can get the gist.
enjoy
adidat
enjoy
adidat
