Rather than start a new thread thought I'd just stick a mini review on here, in case it's of use to someone.
Recently purchased Dakota pocket hole jig in Rutlands Black Friday sale (yes I know their 'Sales' are not always as they should be but I needed some other stuff as well) First time I have used apocket hole jig so cannot compare it to anything else.
The jig comes in a wooden box, with wrenches a small bag of screws, a couple of square drivers and a couple of spare guides as well as drill bit and stop collar. No instructions but all packaged quite well.
First couple of times you use the jig the drill bit tends to bind a bit due to sawdust sticking to the grease on it, quick squirt with WD40 cured that. Also some aluminium swarf first few uses, guess this is the same as other jigs.
You can set the the two drill guides at a dimension and lock them with the allen key, set the stop collar so the pilot drill just misses the base plate (used a black plastic spacer) pop the timber in, clamp it and drill away. You can remove the the drill guides to take it to the workpiece but setting it in place would be a case of measuring or eyeballing. I believe the Kreg jigs come with a little stop and seem better suited to that application.
Good bits.
I was surprised at how strong the joint is.
Pleasantly surprised at the quality for the money, so good value.
Bad bits.
No dust extraction or side hole for the sawdust to escape that are features on the other makes. So feel the drill bit binds more than it should, just need to regularly lift the bit to clear it.
The clamp when it locks down (and you need to push it all the way down to get it to lock) will push the drill guides out of square quite easily, particularly on thicker stock, it seems to me that either the clamp is mounted too close to the guides or there is not enough adjustment on the clamp. The photo shows some scrap that was just over 20mm as a trial, much thicker and I think it would have broken the guides off as you lock the clamp down. (spec on Rutlands website says for upto 1 & 1/2") At some point I shall redrill and tap the base plate Thus giving two positions for the clamp to allow for thicker stock.
No instructions (but its not rocket science) would have been nice to have some guidance on screw sizes.
Only one size of screw included.
So all in all it seems perfectly acceptable for the occasional non professional use that I shall put it to.
