Paul.J
While i have doing some flat work recently,i thought i would use up some of the 18mm scrap ply i have lying around and finally make meself a safer chainsaw platform,as i will be cutting up some logs soon.
Got the idea from Here and have been meaning to make one for ages.
I have made mine slightly higher at 19" and glued and nailed some Oak on the top and bottom edges to give some extra protection against the ply,and i have used some 3x3" pine as the spacers,turned diagonaly to protect the chain from the steel thread bar,in case i go to mad :shock: .
Haven't tried it out yet but will be soon,so will let you know how i get on with it
