Good afternoon to all the members. This is my first post here so please be gentle. I have a ten year old Triton Workcentre which has served me well and we have produced many items of furniture and a new kitchen, however wear and tear on the saw and frame has meant that it is taking a lot of time to adjust/set up, in fact I spend more time on trial cuts than workpieces now so I decided to replace. I took delivery of the Axi TS200 on Wednesday having read the useful and knowledgeable comments on the forum concerning this and its competitors in the budget table saw league. Instructions were next to useless as has been observed by others, no washers for the M6 bolts but I managed to find sufficient in the the toolbox. After several hours I had the thing already to go and put the mitre gauge into its channel with a piece of 50mm sqaure oak for a test cut. Oh s**t!!! , the channel is not is not deep enough for the track, so the mitre gauge sits proud and rocks from side to side. Tried the other channel, this was worse. Tried the sliding carriage channel - this was ok. Measured the depths - 6.6mm on the carriage, 5.4/5.5 on the table. So I phoned Axminster in extreme grumpy mode and they offered to replace, but I more or less told them to stick it where the monkey sticks his nuts. So it is going back for a refund and I have decided to buy the Metabo TS 250 from Screwfix and fit a sliding sled with maybe an incra fence.
Not able to comment on the Axi as I never got to cut with it. Saw seemed very solid and blade rise and fall and tilt seemed to work well. Suspect that the sliding carraige mounting would need to be beefed up as it looks like it could go out of adjustment very easily.
Anyway to anyone out there who buys the the Axi TS200, CHECK that the mitre gauge runs properly before you waste time assembling the thing. Now I have to figure out how the hell to fit all those bits back in the boxes.
