Fromey
Firstly, I'm using the term "bow saw" to mean a wooden framed saw with tensioning cord, as illustrated here;
Secondly, I'm using the term "frame saw" to mean a wooden framed saw where the blade is centrally located within the frame, as in this elegant one here;
(I understand the term "frame saw" tends to be used for both types of saws.)
I'd like to get myself a frame saw, but it appears no-one makes them (I find that quite surprising by the way). I want one so that I can hand resaw wood (to complement my rip hand saw). Without having to make one myself, it looks like the closest thing I can get is a bow saw (of which there are many second hand and even new (e.g., Rutlands sell a nice one)).
Not having used a bow saw before, I suspect you can turn the blade to 90 degrees to the plane of the frame (like with a fret saw) and so be unhindered by the length of the wood one is trying to saw. However, I suspect the asymmetry of this configuration would make it difficult to resaw. Would I be correct in that? Would there in fact be a significant advantage to resawing using a bow saw or frame saw as opposed to a normal rip hand saw (e.g., less resistance making easier sawing)?
Thanks as always for your collective wisdom.
