Push Stick
Dodge
15 Oct 2010
Shelfanger
In my other thread regarding my workshop a few people pm'd me about the push stick they spotted on my table saw so here it is!
Basically two offcuts of birch faced ply with a spacer between them the marginally wider than the side fence meaning that it slides freely - the handle enables it to be pushed easily whilst the angled cut at the leading edge of the birch faced ply also ats as a hold down for the material being passed through the saw.
My main reason for making it was that I hate using push sticks when cutting thin strips as your hand is effectively pushing directly towards the blade with a conventional push stick - with mine your hand is to the side over the fence.
Rog
Hi Rog
Yes, good idea in many respects.
Hand position is good and I like that bevel at the front to give a bit of downward pressure.
I do have a few Buts, though :)
It should be longer; as it is, to push the wood past the blade you need to have you hand in line with the blade. HSE rec 450mm long.
It looks like you are using a full-length fence for ripping. Push-stick or no, that's not a good idea. The fence should have an auxiliary short fence which finishes after the top cutting tooth but before TDC of the blade.
Steve
Steve Maskery":19j6qov6 said:
Hi Rog
Steve
Hi i like the push stick if you have to do a few mod's then you never know some woodwork or table saw company might take the design up.
Thanks tim
Steve
I hope this isn't a silly question but what is 'TDC'?
Thanks,
Jennifer,
Yes, sorry, Top Dead Centre, i.e. the point on the blade where its height is maximum. Before that the teeth are all travelling downwards and after that the teeth are all rising, being a potential source of kickback.
S
Steve, what do you mean by the top cutting tooth? is it possible to mark up a blade so that we can see where the short rip fence should be between?
I'd draw a pic but I don't have time tight now. Sorry.
Height of blade = thickness of timber plus height of one tooth. Put workpiece next to blade and see which tooth is just about to cut into it, Fence much be as far as there but no further than TDC.
Steve
Dibs-h":3bug6tox said:
Doug B":3bug6tox said:
Thanks,
Jennifer,
I know TDC as top dead center
Yeah - usually on Cylinder #1. :mrgreen:
(sorry couldn't resist - getting coat and hat)
TDC applies to any cylinder, the reference to TDC on No.1 is usually the position where the ignition timing marks are aligned. :mrgreen:
Hi, Mick
Not ignition thats usually before TDC.
I don't buy into this, I've had saws with both and its much better (accuracy and ease) with the full length fence. I've never had any kick back with my full length fence but I put this down to always having my fence parallel and always having a riving knife on.
Hear Hear,
I have kept quiet on this but have got to say that i fully agree - A full length fence give far better support and if set up correctly with riving knife in place can only result in greater accuracy. On the contrary I have seen some quite gastly accidents on tablesaws in the past where kickback has occurred due to lack of support from a short fence.
Anyway - A full length fence is what came with my saw as standard - I will not be modifying it!
Yes a short fence can be just as bad allowing the wood to pivot around the blade getting that kickback you see in some American safety videos.
I have the same saw as you Dodge but the 10" and its by far an away my best purchase to date. Will be implementing your little jig as soon as I finish my current project.
I don't like short fences either, far too easy to push the wood so it twists onto the back of the saw when there is nothing to keep it going straight. If the wood starts to move under release of tension I can stop the cut, stop the saw, pull the wood back and recut. I've not had any major mishaps yet using the long fence but, I've had too many close calls using a short one. Personal choice but I go for a long fence.
You'll probably be surprised to hear me say that I agree with you point about support - a long fence does give better support. BUT, and it's a big but, from the point of view of kickback safety a long fence is a much higher risk.
The fact that you have never had a kickback accident and therefore it must be OK is equivalent to saying you don't need to wear a seatbelt because you've never been in an RTA!
Ripping is not a push and forget operation, it requires technique and part of that technique is learning to push forwards.
I'm only advocating a short fence for ripping, not panel-cutting. The further the fence is from the blade the less support it offers, so there does come a point where the reduced support is more of a liability than the risk of kickback, but for ripping a short fence is a kickback-risk reducer.
S
That makes sense Mr M, from a ripping point of view. Trouble with me is, much as I just can't handsaw squarely or level off with a paint brush in remotely straight lines, I can't seem to get 'pushing through straight' quite right; The close calls from not being able to do so out weighs the safety of using a short fence for me.
I think the problems of using a long rip fence come when the timber wants to move, as seen in this pic
This was one piece of beech ripped into 3 lengths - you can see how much the wood moved in the cut. You can also see the fence has been modified for use when ripping - unlock the two black knobs, slide the fence cover back and re-tighten the knobs.
Karl
