OPJ
Not as sophisticated as Steve Maskery's effort in British Woodworking recently however, I'm pleased with what I've achieved in the last day or so. Not sure whether this actually constitutes to being a jig, but hey...! ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Made from 25mm MDF I sourced via. Freecycle last year.
I've kept the fence fairly simple to begin with. I may laminate the front face with Formica and then notch out around the chuck and make some allowance for the swing of the handles (I though a 60mm tall fence would be short enough! :roll
. There is, however, a 6mm hole to store my chuck key! ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The removable insert plate (12mm MDF) is situated slightly off-centre so you can rotate it to use each of the four corners (on both sides! :wink
before having to replace it. 20mm holes in each corner allow for easy removal.
Another little home for my chuck key is found with the aid of this thin magnet I found somewhere... Probably off that cheap magnetic light which stopped working.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![3452353133_2a738c15c6.jpg](https://proxy.imagearchive.com/1cf/1cf18d6f227fceac23115088155b4852.jpg)
![3453169174_647f98e4a5.jpg](https://proxy.imagearchive.com/394/3940cc3f8b17af5363fd28b69b1cfff0.jpg)
![3452353343_ccb4cc99c4.jpg](https://proxy.imagearchive.com/d70/d70ecc1fd733b7251705be8cb9f9516d.jpg)
![3452353735_64ff63a48f.jpg](https://proxy.imagearchive.com/5ef/5eff649e49ff7e850a7ee9b3d1ab3832.jpg)
