TobyB
Can anyone help with this project?
I've been asked to make a table for a kitchen mounted on a 20" wide pillar that can fold away against the pillar, but open up for children to do their homework at, paint or make models at, etc ... and potentially be useful worktop addition for the kitchen.
I've looked on line searching on things like "folding table", here in the forums and general googling ... but not found anything that was too helpful (although the odd ideas) ...
This is the sort of thing I'm thinking of - this is just a hack-up and not even too scale, but the real thing might be 20" wide, 35.5" high (to match the other worktops, and thus 37.5-38" long when erected), perhaps made with 1" thick oak top (to match the other kitchen units) and the legs 1" deep and 2-3" wide (for strength, but allowing to fold down only 2" or so deep against the wall) ...
Is this a sensible design ... I'm thinking of haunched M&T joints to make the legs construct to give reasonable strength, and joining the legs and the top to the wall-mounting block with a long hinge to give a fair amount of torsional resistance to being leant on or bumped. Hoping the legs will "lock" square to the table top by simple abutment, but wondered about some sort of a turnbuckle squared-off block to prevent the table collapsing if the leg is bumped that would rotate clear to allow the legs to fold down flat to the table top.
Searched for long hinges ... I'd like a brass one 20" long - found some "continuous" "Piano" hinges for sale but you need to buy enormous quantities ... anybody have any suggestions for a source?
They wondered if I could make it wider? One idea I had was was to make two 5" wide leaves, again connected with hinges, and make the leg-construct only 10" wide centrally so it still all folded away. Concerned that this might loose a lot of stability with a narrower strut. Also ... how to lock the leaves out and yet it still fold flat ... wondered about transfixing rods through the leaf into the table top ... two or three perhaps each side ... but how to neatly store these would be an additional problem ... thought in the main table top ...
Another idea is to look out three or four of those "flush" double-pivot hinges used in boats and caravans to make two 5-10" wide leaves that would fold flat down onto the top when packed away (adding an additional 1" depth) and be fairly self-supporting when opened out by the abutment. I don't think the visible hinge on the table top would ruin the design, but worried if they'd be strong enough when being leant on in use. Narrower 5" leaves would put less strain on the hinges, but that'd look less neat when folded away ...
A third possibility would be making the unfolded table asymmetrical, with a whole duplicate table top unfolding to the right ... but can't think of how to support this with any legs/brackets that still folded away neatly ...
Has anyone built anything like this, seen any plans, can suggest any "commercial" versions to use ideas from, etc?
